I have been having difficulties with failed meridian flips with the following error, I am using an HEQ5 mount and have been having very inconsistent results with Meridian Flips.
Sequence Generator v 2.4.0.2773, Win7 XP 64, HEQ5 EQMOD
Log to be found here:
[4/16/2015 11:46:59 PM] [DEBUG] [PHD2 Listener Thread] PHD2 - No messages received from PHD2 for 10 seconds, checking socket with status…
[4/16/2015 11:46:59 PM] [DEBUG] [PHD2 Listener Thread] PHD2 GetPhdStatus - Pre-Wait : Stopped
[4/16/2015 11:46:59 PM] [DEBUG] [PHD2 Listener Thread] Sending to PHD2:
{“method”: “get_app_state”, “id”: 1001}
Not sure if this is relevant but I was helping a friend set up dome geometry yesterday and it looks as if the pier Side that EQMOD returns is the wrong way round, East when it should be West and so on. We had to set the OTA offset negative to get the dome position close to sensible.
I was just having the same problems with a similar setup. My logs look almost exactly like yours. After a lot of trial and error and searching I found somethings that might be of some help. Are you running the latest version of EQMOD? You have to set side of pier to physical. Do this in the driver setup, you have to be disconnected from the mount to do this.
From what I can see this should be OK as long as you are South of a line from the East to the pole to the West. Meridian flips should be OK but synchronising a dome north of this will be wrong.
So two issues I had to fix in order for the Meridian Flip to work if it helps someone…
1-My mount was set for JNOW, I changed it to J2000
2-More importantly, EQMOD had a mount limit set a bit before the mount reaches meridian. Solution was to set the mount limits to just past meridian such that SGP can initiate the meridian flip.
