Description
I use auto centering when slewing to a target. I have Pinpoint set up as my plate solver.
I have a successful plate solve on the initial slew. There is an offset error detected. The telescope is moved. Then the next plate solve fails. It goes to blind solver and then solves successfully, and then I am off and running.
When I look at the log file, and compare the first and second plate solve outputs, it shows this:
First Plate Solve (successful)
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] ********** SOLVE ATTEMPT INFO ************
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] SOLVER: False
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] SUCCESS: True
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] CONF: 87
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] BLIND: False
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] RA: 9.92550922455692
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] DEC: 69.0426765321217
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] SCALE: 1.26849852925343
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] FLIPPED: True
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] ANGLE (EON): 91.5686720272563
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] MSG: Matched 87 Stars.
[02/04/20 21:08:45.865][INFO][Telescope Thread][SQ;CE;] ******************************************
Second Plate Solve (Fail)
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] ********** SOLVE ATTEMPT INFO ************
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] SOLVER: False
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] SUCCESS: False
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] CONF: 0
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] BLIND: False
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] RA: 0
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] DEC: 0
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] SCALE: 0
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] FLIPPED: False
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] ANGLE (EON): -500
[02/04/20 21:09:10.106][INFO][Telescope Thread][SQ;CE;] MSG: Solve failed! Failed to solve plate, possibly due to input plate scale being too far off.
Don’t know why all the data is missing in the second plate solve which then causes the fail.
Log attached.
Jerry
Link to Logs
Useful Info
OS: Microsoft Windows 10 Pro
Ver: 3.1.0.451
.NET: 4.8
