Hi Evans,
sorry but it’s totally illogical to press “No” when asked if I want to restore the default direction. The assumption is that the default direction is the correct direction, so why press “No”?
I’m probably misunderstanding what is meant by default direction.
Unless, of course, the default direction is the reverse direction, then obviously I would press “No”. Still, the default direction should be if I send the rotator in a clockwise, it should move clockwise. If the reverse is set, then it should physically run counter-clockwise (which it certainly does not!). So, the reverse function probably needs to be fixed and then maybe SGP will play nice with the Falcon.
Thannks for the support.
Allen
