I have noticed that when centring the scope on a target, the first slew - to the actual target - is fairly fast but OK. I have the scope hand-box set to this value.
After this first slew and solve there is a correction slew. Unfortunately this is a little fast and likely to overshoot the small corrections needed. I have been looking into the control panel etc to identify the settings. To my surprise I found that although the control panel shows the correct setting of focal length (for the f2 configuration) of 560mm, when I check the ‘celestron setup’ tab on the same panel, this now shows 2350mm focal length. This latter is the scope’s native focal length. Are these two settings compatible? I have reset the nudge speed to 02 instead of 0.5, hoping that this is the setting for the second (correction) slew.
Can anyone confirm this?
TIA
Lawrence Harris
