Hi I thought I followed the instructions using \ and _ and % to name my files.
Could someone help me with a clear explanation of where you think I went wrong. I would appreciate your help very much.
Thank you
Joe
Joe
Thank you
Joe
Joe
Joe,
From what I can see, your first image exposed at 2:36 am with an exposure time of 0180 sec’s, cant see the rest because you image run is cut off in the pic after 3:03 am, but, at 4:49 am you began exposing at 0120 sec’s - Somehow you have adjusted your exposure time from 180 sec’s to 120 sec’s. The reason the later ones are showing at the top instead of the bottom is that the files are being listed alpha numerically and ‘0120’ is obviously lower than ‘0180’.
Hope that helps
Paul
