Can you add the “FILTER” keyword to the FITS header for Flat-Dark frames?
I’m exploring using new features of PixInight’s WBPP script and need to be able to tell it how to differentiate my flat-darks when I use the same exposure for two of the filters. The script can use any FITS keyword to group files, so it would be nice if, when doing flat-dark frames, the FILTER keyword was present. We already select the filter for flat-darks in order to induce SGP to use the correct exposure as determined by the flat calibration wizard, though I don’t recall if SGP actually sets that filter since it is a dark frame…
EDIT:
OK, I messed the process up a bit. When setting up an even for flat-darks, I first select Type=Flat, then choose my filter so that the exposure will be populate from the values determined from the Flats Calibration Wizard and stored in the profile. Then I change the Type to Dark. I’ve been doing that for years. Is that the correct process or am I doing it wrong? I just tested with 4.1.803 and this method of creating a Flat-Dark event does not result in a FILTER keyword in the fits file.
Thanks - Shane
