Flat Panel behaviour
Description
Using the Flats Calibration Wizard I have an issue.
Whenever I click on ‘ok’ after the Save Successful pop up, my flat panels open.
This behaviour occurs on both my panels.
One is a Primalucelabs ALTO/GIOTTO, and the other is a Wanderer v4
This is not desirable.
In this case, I intended to increase the brightness for narrowband before calibrating HA/O3/S2
FLAT ISSUE SGP 1
Link to Logs
Useful Info
OS:
Ver:
I have honestly no idea why that is happening. It does not seem to occur with the simulators here. Maybe you could provided logs showing the behavior so we can see how your Flat Box receives the instruction or maybe its an “implied” instruction from some other interaction? Not sure.
