Hi guys.
Is there the possibility of setting up when the flat box shutter opens and closes?
When the scope is parked, if the shutter opens it will hit the observatory wall and the same for closing after an entire imaging session. Can I teach to SGP to: 1) go to HOME position (I mean tube to North, counterweights to the bottom, to the north direction), 2) open the flat shutter, 3) slew to my target in the sequence
and basically the same when the sequence is finished: 1) go to HOME position from the target, 2) close the flat shutter, 3) PARK the mount $) start taking flats…
I can’t automate flats acquiring because I need to check every time if the scope is in a position safe for closing the flat shutter.
