Hello
Is there a way to get 3 digits after decimal ?
I need shorter times for my flats, the dialog box does round them up when I try to enter them. For example my clear filter needs 0.025s to get the right exposure.
Regards
Claude
Hello
Regards
Claude
Hi Claude,
select the the numbers and put in the desired value on the keyboard.
Bernd
Most exposures under about a second aren’t really reliable values because of how they’re timed. Also most manufacturers recommend a minimum of 2 seconds for flats. Can you dim your flat box (by a significant amount) to get some more time for your flats?
Agree with Jared. I put white copy paper in front of my flat box.
Hello
Thank you for yours answers.
No the inverter for my EL panel can’t be dimmed. But I will try to find a way to dim homogeneously the EL screen with a white paper and so increase the exposure time.
Regards
Claude
