Hi, normally I tried looking for a solution on the different forums , but I have no luck to solve this problem.
I have a FLI Atlas , connected to the Proline 16803, and FW, I am using the SGP autofocusing setup and tried different parameters in the SGP setup, and cannot get a normal “V” or even a “U”, My telescope is a FL 1400 , F/Ratio 5.5
I tried first using 2000 steps based on the calculation below:
Autofocus method Data At 1x1 2x2
Telescope FL 1400 Pixel size 9 Read Noise RMS 10e-
Number of steps 105000 resolution per steps 0.083 Micros/step travel 0.35" 8.89mm
CFZ Critical Focus Zone
Ha 3nm 656.3 95 95
OIII 500.1 72 72
SII 671.6 97 97
Red 650 94 94
Green 510 74 74
Blue 475 69 69
Formula CFZ / Focuser step size Multiply by 1.5 and 2
Ha OIII SII Red Green Blue
(CFZ / Focuser step size) x 1.5 = focuser step size 1,716. 1301 1753 1698 1337 1246
(CFZ / Focuser step size) x 2 = focuser step size 2,289 1734 2337 2265 1783 1662
But when I tried using Ha, with a 2000 initially there were erratic ‘V’ shapes, it started fine on the first point , then followed by a higher point on the second data point, giving a zic-zac shape, I reduced the steps to 500 ,and up to 3000 without success.
This morning I have included a backlash (IN wards) of 500 , but not sure if even the 500 is correct, I read to use the following formula :step size/4 (2000/4), I wanted to see if this will better the V shape as the focuser starts pulling back.
I read in a forum that someone using a FLI Atlas used 200 steps , if the focuser number of steps is 109,000 (say 1 steps = 0.0000846mm), so 200 will move only 0.01692mm which seems too little, but not sure because I haven’t tried it.
My normal work flow is first to try manually the best focus possible, this is my starting point, my SGP setting is the following:
Exposure Time 10sec
Bin 2x2
Data Point 7
Step Size 2000
I thought that the focuser payload could be a problem after having it for four years, but my setup weight is much less than 11 kgs.
Any suggestion will be appreciated
Charles
