Trying to do flats with Flip/Flat. I set the brightness level in the flat box window but when I check run the light goes off. It does continue to run the sequence. Help. Both programs are up yo date.
If you have the FlipFlat connected to SGP then you need to be controlling it through SGP for the brightness. Furthermore you’ll need to setup the brightness in the Filter Setup for different filters and binning:
Thanks,I figured it out last night.
