Focus Control docking module after saving the ASCOM driver settings and connecting to camera.
Note, Current Position is not zero. it is 10,000 which was saved as the Max Value.
If I understand you correctly, the total travel of your focuser is 10000 steps in to from one end to the other, and your starting your system with the focuser racked fully in, if so that position will either be 0 or 10000 depending depending on the ‘polarity’ of you travel. So that on initial movement the motor will either rack up from zero are down from 10000…
Where you are showing 10000 as the steps for coarse & fine movement, will attempt to fully move the motor from one end of travel to the other, so going through the focus point…
Personally, for fine & coarse movement I set mine to 15 and 30 respectivelly…
