Hi!
The Temperature Compensation stopped working about a month ago. All set in control panel to compensate 10 points per degree but nothing happens.
Here’s the part of the log pertaining to it:
[09/24/21 22:46:01.014][DEBUG][Sequence Thread][SQ;] Temp Compensation: Using focuser temp…
[09/24/21 22:46:01.046][DEBUG][Sequence Thread][SQ;] Temperature compensation: Temperature change is -0.194 degrees (end temp: 7.306 - temp comp marker: 7.5); Requesting relative adjustment of 2 steps…
[09/24/21 22:46:01.046][DEBUG][Sequence Thread][SQ;] Temperature compensation: No minimum threshold found, defaulting to 15% of AF step increment: 50 → 7.5 steps
[09/24/21 22:46:01.046][DEBUG][Sequence Thread][SQ;] Temperature compensation: Focuser position error not large enough, skipping…
Not sure why it thinks error is not large enough when the temperature drop is -0.194* even though there’s a request to compensate by 2 steps…
Thanks!
Ian
