Folder Directory
Did something (or did I) change something?.. SGP all of a sudden starts putting my captures in 3 or more different folders (1 target).
Version 3.1.0.232
Cheers
Not that I am aware of… you’ll probably want to provide the sequence.
Thanks Ken, I’ll figure out how to do that.
I thought it may have something to do with the %Filename keys (I did change that).
For my Directory, I just browse to a folder and choose it… I believe it was working properly until I installed the Beta (not sure tho).
Cheers
Here’s a few sg_logfile_20191010210204.txt (869.9 KB) sg_logfile_20191010234237.txt (147.6 KB) sg_logfile_20191011205750.txt (15.0 KB)
You say you changed the filenaming pattern…you got your whole reason there.
Seems you changed all underscores with dashes…here’s your file naming pattern: %tn%ct%el%fn%dt%tm
Creating
:\SGP\LBN591\NA\600sec\frame55\2019-10-12113934.
Here’s my file naming pattern that you cak check out of you like: %tn%dt%tn_%ft_%fe_%el_%bi_%ct_%dt_frame_%fz
Creating:
\SGP\LBN591\2019-10-12\LBN591_Light_Ha_600sec_1x1_NA_2019-10-12_frame_0055.
Ok, thanks for that… I’ll change that over. (At the bottom of the “Key” pop up window, I thought it meant we could use either ; underscore or backslash.
