Hi, my setup is fixed inside an observatory, so dont need constand 'force guider calibration 'when i start the sequence, so , is there an option on SGP to just select a star in PHD and start guiding?
CD
Yes, that would be the normal behavior for PHD2, as long as PHD2 does have calibration data stored in the PHD2 equipment profile you are using. This is identified by “Cal” in green letters bottom right. Calibration is only forced when you hold when clicking the green Guide button.
SGP is not able to force PHD2 calibration as far as I know. Presumably PHD2 will only do that or request to do that when calibration data is unavailable in the used profile (“Cal” in red letters).
