I love using this - but obiously I’m doing something wrong.
Although I lose the current sequence, I also close all image tabs to start clean.
I call the target in F and M wiz. I set the rotation and frame. I tell it to create target and it does. I then need to set my file area. D:\ (I enter in the new dir).
done - and save.
I then CLEAN THE FILE (IMAGE) and sequence and I start to create another. I did this with around 7-8 targets each saved under it’s own target name and now when I go to load them.
I get ALL the images of all the F and M wizard targets appearing into each of the SEQ I created. Even the path is wrong (to yet another target path) even thought I paid carefully attention to not make an error.
What am I doing wrong? Even though I got into SEQ manage seq file and delete the images, and resave things still get messed up. I KNOW when I created the target frame and sequence that the target was the ONLY IMAGE when I saved.
I’ve created all sorts of targets this way and now that I’m done I have a hobbled up mess of doc files with targets and directories that aren’t right. It’s SO frustrating.
