Frame & Mosaic Wizard Foto from Target
to plan my sessions i created a few targets in a sequence out of the ‘Frame & Mosaic Wizard’; wonderful tool :slight_smile:
But when i’m opening the sequence a few days later, i don’t see the choosen section any more.
So now my question respectiveley my wish: Is there a way to get back to the choosen section in the FM-Wizard out of the coordinates of the target? Would be very nice for me, maybe also for anyonbe else!?
I don’t know if there is a way to add the image to the sequence after it has been created but, if you select “Associate working image with sequence” at Framing & Mosaic Wizard | Mosaic Sequence > Other Options SGP will show the image when the sequence is opened.
Hope this helps,
BobT
Hey BobT,
Thank you :pray:
That’s not exactly what i’m thinking about (kind of ‘reverse framing’), but for the sequence i will create in the future it will help a lot!!
Clear Nights
Didi
Are you meaning the “Working Image”? Basically the image of the Framing and Mosaic Wizard as it was created? There is an option to “Associate Working Image With Sequence” whenever you create the Sequence with the FMW. Or am I not understanding what you’re after?
Thank you,
Hey Jared,
Thank you for your answer; now i know what this ‘option’ is good for (and will never forget it :wink:).
What i meant, was to generate this so called “working image” if you forgot to tick this option.
But now i know that i always have to tick it; and the problem is solved :ok_hand:
Thank you
Didi
