Gain setting in event dropdowns?
Would it be possible to get a Gain setting dropdown in the event planning window that would override the equipment profile gain setting? Maybe replace the “Suffix” with Gain - so the event setting thought process in the plan would be Type, Filter, Gain, Exposure, Repeat?
I seem to remember there used to be an ISO dropdown and there was chatter about adding a gain setting in addition/in its place. The ISO is gone, but the Gain has not been added. (I think I’m remembering that correctly!)
In the meantime, is there any way to get a different gain for a specific event (e.g., for the OIII filter) within a target sequence? Right now I’ve got separate equipment profiles set for each Gain setting with a given set of equipment, and the full target sequence is built using those equipment settings - is there a better way??
Suzanne
You can click the gear icon on the left side of an event and change the gain and offset there. Just isn’t enough real estate for an actual drop down with the filter and others I suppose.
Dave
we have definitely toyed with the idea of reformatting the event table with more common things, but alas, other things seem like more popular requests so we have not done that yet. Certainly a reasonable idea tho
