Hi, when setting up for a sequence, is it possible to set the camera gain to have different values for each filter, or wouldn’t it really make much difference? It just seems that with less light getting to the sensor I assume that the gain needs to be increased. If it is possible to do so, how is it done?
Kind regards,
P.
You can set the gain for each event in a sequence, see below. However note that with some cameras, like my QHY163M, I cannot set the gain unless the camera is actually connected through SGP.
In the sequencer window:
Then in the Event Options:
Thanks Joel,
unfortunately that box doesn’t come up on my screen but that may be because my trial period has just ended. I’ll be buying the licence in the coming weeks so, hopefully, it will magically appear!!!
Kind regards,
Phil
