General workflow with TheSkyX Pro....getting started again
I have made a few changes to my observatory. Got rid of Fosters Systems controllers and installed MaxDome II controllers. Ready to put some more time into learning Sequence Generator Pro again. Simple first questions is about starting sequence.
TheSkyX pro must home my Paramount mount before it does anything else. I am wondering what workflow people with TSXPro and Paramount mount’s use when initializing mount and sequence. Or is it simply starting TSXPro and homing the mount then start sequence?
I have spent some time experimenting and researching this too. I wrote my own ASCOM driver for our clam shell dome. The only procedure that worked well for me was the following: Connect to TSX (either through SGPro or by launching TSX separately -> Home the mount -> Park the mount -> Start the sequence. Unless the mount is homed and parked, SGPro will not open the shutter correctly.
+1 I have a ROR, I connect to everything (TSX ASCOM driver does NOT home the mount on connect), open roof and home/park mount. In this position it acclimatizes and then I start the timed sequence from park.
In my case the park position is pointing horizontal North, so if there is any issue with weather, my own roof controller can safely close the roof without PC assistance.
