I tested the SGPro SW and I am really positive to purchase it together with the mosaic sequencer option soon. But I have one question: So far everything worked well except the connection between SGPro and the mount. My equipment is as follows:
- EQ6 (white version)
- Camera: Atik One 6M with Atik GP cam as the guiding cam
- The connection of the cam and mount to the laptop is done via a separately powered USB hub
- Between mount and the USB hub I am using the Pierro USB / Mount interface (see here: http://www.teleskop-express.de/shop/product_info.php/language/en/info/p7971_Pierro-Astro-USB-Guider-Autoguider-Interface—USB-3-0.html
- The imaging SW is from Atik (Artemis)
As guiding SW I am using PDH2 (here I connect the guider cam via the Pierro USB IF to my mount; works well). Might this be the problem that SGPro cannot connect to the mount?
What ever I tried, the connection between mount and SGPro was never
accomplished. Or might this be a configuration issue in the ASCOM SW?
Do you have any idea what I can do connect SGPro to the mount as otherwise the mosaic option might not make sense, I guess?
Thanks for any
feedback!
Thomas
