I am using your 32 bit version 4.5.0 with ps2, ps3 and ansvr. I have accurately placed the scope camera data. I can get the program to blind solve images without a problem however plate solving coordinates for a goto is a complete failure. It will go to the rough direction of the target, initiate a plate solve with an image it downloaded and then spin its wheels for as long as I can tolerate 5-10 min. By then the entire program hangs and I have to kill it by using alt, control delete. This was happening before I downloaded and installed ps3. BTW the computer says the latter is installed proper log file [10/12/26 15:56:17.717][DEBUG][Unknown][NONE] .NET Framework Version: 4.8
[10/12/26 15:56:17.717][INFO][Unknown][NONE] ASCOM Platform version: 7.1.3.4851
[10/12/26 15:56:21.095][DEBUG][Main Thread][NONE] SGPro retail license…
[10/12/26 15:56:21.989][DEBUG][Unknown][NONE] API successfully started on port 59590…
[10/12/26 15:56:22.866][DEBUG][Unknown][NONE] FileManager.Deserialize: Await serialization lock…
[10/12/26 15:56:22.866][DEBUG][Unknown][NONE] Performing Deserialize…
[10/12/26 15:56:22.883][DEBUG][Unknown][NONE] Error loading notification settings! Could not find file ‘C:\Users\Charles\AppData\Local\SequenceGenerator\Sequence Generator Pro\notifications.sgd’.
[10/12/26 15:56:22.919][DEBUG][Main Thread][NONE] ===== S E Q U E N C E G E N E R A T O R v4.5.0.1652 (32-bit) =====
[10/12/26 15:56:23.006][DEBUG][Main Thread][NONE] OS: Microsoft Windows 11 Home
[10/12/26 15:56:23.988][DEBUG][Auto Guider Error Thread][NONE] Entering Auto Guider message dispatch loop…
[10/12/26 15:56:23.989][DEBUG][Focuser Thread][NONE] Entering Fouser message dispatch loop…
[10/12/26 15:56:23.989][DEBUG][Camera Thread][NONE] Entering camera message dispatch loop…
[10/12/26 15:56:23.990][DEBUG][TEC Thread][NONE] Entering TEC message dispatch loop…
[10/12/26 15:56:23.990][DEBUG][Filter Wheel Thread][NONE] Entering Filter Wheel message dispatch loop…
[10/12/26 15:56:23.990][DEBUG][Telescope Thread][NONE] Entering Telescope message dispatch loop…
[10/12/26 15:56:23.990][DEBUG][Rotator Thread][NONE] Entering Rotator message dispatch loop…
[10/12/26 15:56:23.990][DEBUG][Auto Guider Thread][NONE] Entering Auto Guider message dispatch loop…
[10/12/26 15:56:23.990][DEBUG][Dome Thread][NONE] Entering Observatory message dispatch loop…
[10/12/26 15:56:23.991][DEBUG][Safety Thread][NONE] Starting safety monitor…
[10/12/26 15:56:23.991][DEBUG][Environment Device Thread][NONE] Starting environment device monitor…
[10/12/26 15:56:23.999][DEBUG][Unknown][NONE] Settings changed (or loaded)…
[10/12/26 15:56:23.999][DEBUG][Unknown][NONE] ****************** SETTINGS DUMP **************
[10/12/26 15:56:24.007][DEBUG][Main Thread][NONE] Camera is not connected and sequence not running, auto reconnect aborted.
[10/12/26 15:56:24.012][DEBUG][Main Thread][NONE] ASCOM Observing Conditions Hub (OCH)
[10/12/26 15:56:24.012][DEBUG][Main Thread][NONE] ASCOM Observing Conditions Simulator
[10/12/26 15:56:24.012][DEBUG][Main Thread][NONE] ASCOM OmniSim ObservingConditions
[10/12/26 15:56:24.012][DEBUG][Main Thread][NONE] JustAHub ObservingConditions (for 32bit drivers)
[10/12/26 15:56:24.012][DEBUG][Main Thread][NONE] JustAHub ObservingConditions (for 64bit drivers)
[10/12/26 15:56:24.012][DEBUG][Main Thread][NONE] OpenWeatherMap ObservingConditions
[10/12/26 15:56:24.012][DEBUG][Main Thread][NONE] TEMPerHUM
[10/12/26 15:56:24.012][DEBUG][Unknown][NONE]ly. sorry i do not have dropbox
If you want to provide logs showing the issue, we are happy to look. No Dropbox required and you can send logs right from the SGPro app.
