Guiding Tab, PHD2 "Settings"
If the location where PHD2 is installed is provided to SGP then pressing on the “Settings” button launches PHD2 and the “PHD2 Connection Settings” interface. The interface appears to be a way to set a PHD2 profile, set a couple of conditions and then connect or disconnect PHD2 gear.
How necessary is to reach PHD2 through this interface? The option “Connect gear to PHD2 when sequence starts” seems to not consider that simply starting PHD2 and connecting gear does not initiate guiding. So it seems to me that once the location where PHD2 is installed is known to SGP the “Settings” button does not necessarily need to be used.
Any thoughts on this?
Farzad
