I’m trying to get into astrophotography. I have a Skywatcher EQ6 pro mount which is connected through a Starsense autoalign hand control. I’ve installed the ascom drivers for Skywatcher mount but am not able to connect to the mount through Sequence generator pro.
Can someone walk me through the process.
Thank you in advance.
Ravi.
If you are trying to connect through the Celestron HC using the port on the base of the Celestron StarSense HC then you need the Celestron driver.
and the PL2303 driver so that the Series to USB module in the HC could be understood by the laptop
