How to get rid of this warning for switch simulator?
I installed 4.0.0.617 last night. Initially it was having problems with my Digital Logger Web Power Switch 7 but I think that might be working now.
But every time I start a sequence I get this box:
I have not found a way to make it not appear requiring an extra button push on something I’m not using. Am I missing something?
Chris
Nope, having the digital logger ASCOM driver installed causes SGP to hang at “validating sequence and connections” when I run a sequence.
Chris
How did you get all of those simulators installed?
They were there in the control panel when I installed SGP v4. I didn’t install anything else.
Last night I had to revert back to v3.2 to get SGP to run. This evening I deleted the Switch folder in the ASCOM folder under Program Files x86. SGP v4 runs now without the warning box mentioned above. The Digital Logger ASCOM driver was uninstalled last night. It went past the “validating sequence and connections” message without freezing up.
Chris
