Humidity sensor from QHY268m
the QHY268m has a humidity and air pressure sensor built into the camera body. The humidity sensor in particular would be interesting to see right next to the temperature sensor. In this way, dew problems or icing can be detected by the sensor at an early stage.
Thank you and best regards
Daniel
In general, SGPro will follow features that the ASCOM group exposes in equipment. If ASCOM adds functionality for this, we will add it to SGPro for sure. You can also get an environment device that will give you warnings about weather that is less than ideal for AP.
