Hello! I am confused about the Time Constraints in the Target Settings box.
I created a sequence in which I wanted to image an object unless it fell below 30 degrees west at the start of the target sequence - about 8:30 PM. I entered the altitude and time and locked the constraint.
When I opened the sequence last night, SGPro told me that targets were out of range of start/stop and the target would be skipped. When I checked the target, settings, the altitude remained at 30 degrees - but the time had changed to when the object rose above 30 degrees east, or about 12:30 PM - before the run time -so SGPro would not run the target since the event time end time was already past.
I reset the time constraint and ran the sequence.
I am confused why SGPro updated the time constraint to 30 degrees East instead of keeping the time and altitude for 30 degrees west. Thank you and best regards.
