Hi. I tried to have a look and I thought I had asked this before. Is there a way to identify which equipment profile is applied to a particular sequence?
Cheers and clears!
Cheers and clears!
This does not make sense because any changes you make since you created the sequence using a profile will “stick” with that sequence and therefore no longer match the original profile.
I think that is why that part of the header was removed from SGP a while back.
Personally, I would like to see that come back to the header but set up in such a way that there was some indication as to whether the full base profile still applies or if changes to the setup for that sequence had been made since that sequence was created using that profile
