Hello! I am getting acquainted with SGPro.
A quick question - is it possible to schedule an image sequence for when a target is in a particular place in the sky?
Common locations would be objects at the meridian or above 30 degrees altitude.
The first would provide optimum camera conditions, if needed. The latter, for time series work when images might degrade when under 30 degrees altitude, so starting the sequence when the object rises above 30 degrees in the east and stopping when it drops below 30 degrees in the west would be helpful.
As I read the manual, it appeared that start times were easily put into the sequence, but I was not sure how to put in sky location information. I can get these times from a separate planetarium program; however, the times of for these events would change day by day, so the sequence would need to be manually updated with the timing information for each run in that case.
Thank you for your help and best regards.
