SGP works so well for me lately I firstly have to say thank you for that, and the new Beta.
I have only one feature request which would dramatically improve composition time on large projects where I can use a spread sheet to manipulate data and slash the time-consuming mouse clicks required when dealing with hundreds of control parameters in a large project.
The mosaic tool is great and easy way to start a composition but it doesn’t scale up well.
I could use a simple import/export of targets and co-ordinates to a CSV file format with any suitable delimiter or format that tools like Excel (or a database) can understand.
Putting in an binning, filter , delay, duration, exposures et.al. even better.
If an entire sequence, or even just its’ non-profile elements, could be exported to any simple CSV format, such that it can be amended and or cloned and re-imported faithfully, that would be perfect (and probably impossible).
As I understanding you are considering supporting sequence chaining or a sequence control hierarchy or such, this feature also covers a similar area of supporting ‘larger’ project requirements.
Gee … not asking much huh? I’m a code monkey too so it would probably be easier to deliver xml and I would happily take that too
Many Thanks
Ian
** I looked at the SGF file format, but without a schema beyond me, and the available API’s which
seemed to be all control related.
