In sequence flat calibration
Request to add flat calibration before taking flats in a sequence,
Do your values for flats change often? The idea was that calibration really only needs to be ran once.
I’m using a very fast system (f/2.8) and my flat panel (self made LED panel), which is mounted in my dome, seems to be affected by temperature. As the temperature varies also the luminosity varies slightly which has a noticeable effect on the flats of this very fast system. Doing a calibration before taking the flats would assure correct flats.
Maybe the future skyflats option would be able to do this?
Distinctly possible, though I don’t seem much variation in my Flip-Flat. Mind you, it’s probably not as big as your panel.
How will the skyflat option work?
