<I just downloaded SG Pro launched it and it throws multiple windows in front of the main window.like focuser start. No matter what I click I can’t close them>
Link to Logs
Useful Info
OS: <Windows 11> Ver: <I can’t access the Help menu because of all the locked windows in front of it. >
If you can’t close a window, chances are it’s not the active window. Try Alt-Tab to get to the active window, and take a screenshot so you can share it with @Ken, then close that window.
You may need to try Alt-Tab several times to find the active window.
Can you move the “multiple windows” so they are not on top of each other, then take and share a screenshot?
Thanks! Can’t ALT-TAB between the SGPro windows. Trying to move them elicits a DING!! I’m attaching screen shot. Please note this is the first boot after installation before I enter license
A DING almost always means you are trying to do something on a non-active window. @Ken will have to answer. He may need the log file from when this happens.
Once you have SGP running, you should be able to hide the windows you don’t want and dock the windows you do want.
It looks like you have the production version and not the beta? The Control Panel has changed a lot.
Yes I have the production version. I can’t even move the window in front which is prompting me to connect with hardware. I don’t have hardware installed yet and I can’t dismiss the prompt.
I’ll wait to hear from Ken but may just uninstall and try again. Should I go for the beta?
