Within the second target sequence ten flats were scheduled. Flat frames 0004 and 0010 however did not have the flat panel brightness set to the expected 255, instead the panel was set at 000. This anomaly occurred a little after 01:24 onwards. The remaining flat frames were taken correctly. It is not the first time I’ve experienced this anomaly using my Arduino controlled flat panel via the Alnitak protocol. On this occasion I’d select the _Old instance for the first time to see if this instance performed better. Please note that it is only since using SGPro versions 3.2.0.660 and beta version up to 4.2.0.936 that I’ve had this issue. Unfortunately I cannot recall in what version I first had the problem.
I believe this or similar has been reported by others too.
Link to Logs
Approx time of issue: 01:24
Useful Info
OS: Microsoft Windows 10 Pro
Ver: 4.3.0.1090 (64-bit)
.NET: 4.8
ASCOM: 6.6.1.3673
