The last couple sessions a warning box has popped up on start up, saying that “the astrometry.net server you have specified (http://127.0.0.1:8080/api) cannnot be reached and will not be used.” Any idea what I need to do to fix it? I’m not sure what changed, but it’s been running fine as a blind solve failover to PS2 for several years.
If you put this link into a browser ( ansvr config) does it respond ? if not, then the local server isn’t running so you need to re-start it (one of the links in the start menu)
Thanks Doc! It didn’t respond, and unfortunately even when I run Start ANSVR from the start menu it still doesn’t respond, and SGP still gives me the same error message. Rebooted and restarted SGP and ANSVR, but same result. Any idea what the problem is?
I think that was it, since the warning box no longer pops up at sequence start. But I notice that SGP won’t blind solve an image. When I load an image, rt-click and select blind solve, after about ten seconds I get a failure notice. Should that concern me? Thanks for the help. It’s been years since I’ve even thought about ANSVR.
