Is there an "End of Target" Setting to stop tracking?
I have a sequence that includes a Target of Lights, then a Target of Cal Frames for Bias and Dark, then a Target for Flat Frames. I set the Lights target to finish at 3:00 am, then do the cal frames. I want the scope to park at the end of the Lights, and there’s no apparent way I can do that easily as it’s no included in the general Target settings. I cycle through events so it doesn’t appear I can use end of event settings to do this.
PS I also want to turn off autoguiding after the Lights target
What you’re looking for is the “Event Settings”. About half way down:
http://mainsequencesoftware.com/Content/SGPHelp/Events.html
Thanks Jared,
Ok what I did is set a park command pre the first event in the Cal Frames target - we’ll see how it goes tonight
Wayne Hixson, Stargazer
That seems to work. I wasn’t sure because it said the Event actions only apply when you’re finishing one event at a time, rather than cycling them as I do
