Looking for a trial version of SGP 4.5
I have been using SGP 3.1 - 3.2 for a long time, and now I would like to try out some of the features offered by version 4.5. However, I have not been able to find any information regarding trial versions.
I’ve only found where to download version 4.5, but I don’t know if this is also a trial version. If so, I have several questions, but for now: how long does the trial last, can I import settings from previous versions (specifically 3.2)?, Can I use both versions?
Thank you,
Trial is 45 days. Download SGP4 and it should automatically start a trial.
You cannot currently have both versions installed as the newer version will overwrite your existing SGP install. Sequences and Profiles created with SGP3 will work fine with SGP4. Though I would recommend copying that data and storing it someplace since using profiles or sequences in SGP4 will upgrade that data in place.
Thank you,
