Twice in conjunction with a Windows update ready for installation (I don’t know if this is the cause), the main camera disconnects and no longer connects until the SGP application is restarted.
Link to Logs
Approx time of issue: 01:52
Useful Info
OS: Microsoft Windows 10 Home Ver: 4.2.0.1158 (32-bit) .NET: 4.8 ASCOM: 6.6.2.4195
I can’t think of any reason that the Windows notification about an update would matter to the ASCOM driver. You seem to have attached the wrong set of logs.
Ah OK. This is almost certainly a USB hub issue. Either power fails when it gets too cold, or the mount’s position strains connections, gravity, etc. It’s not just the camera… At 01:39:32 you literally lose connections with all of your gear.
