How can I configure the SGP so that the telescope only changes the meridian? And keep following up.
Are you saying you want to image through the meridian? Not do a meridian flip?
Exactly The telescope not do a meridian flip.
How can I program it?
Going off my goldfish memory:
It’s in your equipment profile.
I believe it’s “TOOLS” - “EQUIPMENT PROFILE” then select the profile you want to change, under the TELESCOPE tab they’re is a check box for “USE MERIDIAN FLIP” or something like that. check that box and next to it is a box that says “SET” I’m there set the amount of time you want the Mount to flip after getting to the meridian.
If you don’t want it to flip, uncheck the “USE MERIDIAN FLIP” box.
Then click on the OK boxes and the SAVE box under the hardware profile.
Additional guidance is here:
https://help.sequencegeneratorpro.com/TelescopesMounts.html
See the section on Use Auto Meridian Flip
