Attacehd is the log. I am using Explorer Scientific Losmandy G11 PMC8 mount with QSI CCD. I was able to automatically perform meridian flip in earlier versions but it doesn’t happen now, with the latest 3.1.0.544 version of SG Pro. Is this happening with anyone else as well? Or can anyone help with with what can be the issue. I am using ASCOM Platform 6.2 to control the mount.
Log::::::::::::::::::::::::
[10/13/20 02:28:03.893][DEBUG][Sequence Thread][SQ;] Running blocking meridian flip…
[10/13/20 02:28:03.893][DEBUG][Main Thread][SQ;] Adding sequence level notification: Running automatic pier flip…
[10/13/20 02:28:03.896][DEBUG][Sequence Thread][SQ;] Sending Notification: Status - Running automatic pier flip…
[10/13/20 02:28:03.930][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Starting Meridian Flip Procedure
[10/13/20 02:28:03.930][DEBUG][Pier Flip Thread][SQ;MF;] Meridian flip: Skipped initial plate solve, use target as reference…
[10/13/20 02:28:03.930][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Stopping the Auto Guider
[10/13/20 02:28:03.931][DEBUG][Pier Flip Thread][SQ;MF;] Attempting to stop PHD2 guiding…
[10/13/20 02:28:03.931][DEBUG][Pier Flip Thread][SQ;MF;] Checking PHD2 state…
[10/13/20 02:28:03.931][DEBUG][Pier Flip Thread][SQ;MF;] PHD2 GetPhdStatus - Pre-Wait : Guiding
[10/13/20 02:28:03.931][DEBUG][Pier Flip Thread][SQ;MF;] Sending to PHD2:
{“method”: “get_app_state”, “id”: 1001}
[10/13/20 02:28:04.031][DEBUG][Pier Flip Thread][SQ;MF;] PHD2 GetPhdStatus - Post-Wait: Guiding
[10/13/20 02:28:04.031][DEBUG][Pier Flip Thread][SQ;MF;] Sending to PHD2:
{“method”: “stop_capture”, “id”: 1004}
[10/13/20 02:28:04.031][DEBUG][Pier Flip Thread][SQ;MF;] Checking PHD2 state…
[10/13/20 02:28:04.031][DEBUG][Pier Flip Thread][SQ;MF;] PHD2 GetPhdStatus - Pre-Wait : Guiding
[10/13/20 02:28:04.131][DEBUG][Pier Flip Thread][SQ;MF;] PHD2 GetPhdStatus - Post-Wait: Guiding
[10/13/20 02:28:05.131][DEBUG][Pier Flip Thread][SQ;MF;] Checking PHD2 state…
[10/13/20 02:28:05.131][DEBUG][Pier Flip Thread][SQ;MF;] PHD2 GetPhdStatus - Pre-Wait : Guiding
[10/13/20 02:28:05.131][DEBUG][Pier Flip Thread][SQ;MF;] Sending to PHD2:
[10/13/20 02:28:05.231][DEBUG][Pier Flip Thread][SQ;MF;] PHD2 GetPhdStatus - Post-Wait: Stopped
[10/13/20 02:28:05.231][DEBUG][Pier Flip Thread][SQ;MF;] PHD2: Successfully stopped PHD2…
[10/13/20 02:28:05.231][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Sending Telescope command to execute meridian flip
[10/13/20 02:28:05.251][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: Pier side is West
[10/13/20 02:28:05.251][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: attempting pier flip using sideOfPier
[10/13/20 02:28:05.314][DEBUG][Telescope Thread][SQ;MF;] Setting Pier East
[10/13/20 02:28:05.619][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: Waiting until pier side changes…
[10/13/20 02:28:40.152][DEBUG][Main Thread][SQ;MF;] PopulateDataModel: Transferring view to the data model…
[10/13/20 02:28:40.154][DEBUG][MF Update Thread][SQ;MF;] Performing serialize…
[10/13/20 02:33:06.048][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: Side of pier timeout!
[10/13/20 02:33:06.062][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: Pier side is West
[10/13/20 02:33:06.567][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: Failed to flip because starting pier side and ending pier side are the same!
[10/13/20 02:33:07.567][DEBUG][Telescope Thread][SQ;MF;] Telescope thread is IDLE…
[10/13/20 02:33:07.571][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Telescope command to meridian flip has completed
[10/13/20 02:33:07.571][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Telescope failed to perform meridian flip
[10/13/20 02:33:36.892][DEBUG][Main Thread][SQ;] Adding sequence level notification: Failed to complete automatic meridian flip, aborting sequence!
[10/13/20 02:33:36.901][DEBUG][Sequence Thread][SQ;] Sending Notification: Error - Failed to complete automatic meridian flip, aborting sequence!
[10/13/20 02:33:36.902][DEBUG][Pier Flip Thread][SQ;] Meridian Flip: Procedure complete
[10/13/20 02:33:41.719][DEBUG][Sequence Thread][SQ;] Blocking Pier Flip: Failed to meridian flip, aborting sequence (False)
[10/13/20 02:33:41.719][DEBUG][Sequence Thread][SQ;] Aborting sequence: Failed to meridian flip
[10/13/20 02:33:41.719][DEBUG][Sequence Thread][SQ;] Set sequence abort
[10/13/20 02:33:41.721][DEBUG][Main Thread][SQ;] Adding sequence level notification: Failed to meridian flip, aborting sequence.
[10/13/20 02:33:41.730][DEBUG][Sequence Thread][SQ;] Sending Notification: Error - Failed to meridian flip, aborting sequence.
[10/13/20 02:33:41.730][DEBUG][Sequence Thread][SQ;] EventMarker(3) - t:M77 (0); e:1; f:0; o:* aborted *
[10/13/20 02:33:41.730][DEBUG][Sequence Thread][SQ;] EventMarker(10) - t:M77 (0); e:1; f:0; o:* aborted *
[10/13/20 02:33:41.730][DEBUG][Sequence Thread][SQ;] Set sequence abort
[10/13/20 02:33:41.731][DEBUG][Sequence Thread][SQ;] Run event requested sequence abort…
[10/13/20 02:33:41.731][DEBUG][Sequence Thread][SQ;] ********* Run post sequence *********
