Is there a way I can do a 10min meridian flip, before it hits the meridian in sequence generator pro? My explore scientific 102mm keeps hitting and getting stuck on the tripod leg I have a (Orion Atlas eq-g) running Eqmod also thanks everyone
You can certainly set up SGP to do so but it depends on the capabilities of your mount for it to work. Some mounts can only be flipped by issuing a Slew command after the mount is past the meridian.
Awesome thanks for the info!
