Meridian flip question and a possible enhancement for beginners
I have a request for Meridian flip.
I am using EQMOD on Atlas 6. I have read everything about EQMOD and SGP and Meridian flips. I am running into the following problem:
  1. If I set SGP to flip on exact time (setting of 0 minutes), my equipment is very close to the current tripod leg - but the flip causes it to hit the other tripod leg.
  2. If I set the number to “negative number” - let us say -2 minutes, my equipment is safe before the flip - but after the flip it hits the other leg super hard!
  3. If I set the number of positive number - let us say 1-2 minutes, it hits the leg before the flip - but is good after the flip.
I would be a lot simpler feature for me if I could “bracket” meridian flip i.e. have two settings:
  1. Go to Park Position “X” minutes before Meridian Flip.
  2. Go to Target “Y” minutes after Meridian Flip.
This will allow me to give a good buffer of 10-15 minutes before and after the meridian and very easy to understand for a beginner trying to automate this.
As it is currently, I cannot use automatic meridian flip in SGP - unless someone has some creative ideas.
You could get a pier extension for the Atlas.
The other thing that sometimes buys me a little room is the following: The Altas has a “pin” for the azimuth adjuster that can be placed in one of two diametrically opposite threaded holes on the pier plate. When I am imaging North, I set up the azimuth adjuster over one leg and place that leg and the azimuth adjuster N. When I image S I place the azimuth adjuster between two legs and place the other leg S. The azimuth adjuster obviously always stays N in both configuration. Your mileage will vary depending on the length of your scope, and imaging train, and the location of your target. If you try this, check for stability before your move your scope around. Try mimicking the flip by hand slowly and indoors and under controlled conditions before heading out to image. All the best.
Ajay
Thanks. The pier extension seems promising. It may just be enough for my camera equipment to clear the tripod legs on both west and east side of pier.
However, I think the SGP software development team should consider my suggestion - if I can tell SGP to park at a specific point before meridian, wait for some time and then continue on the other side, it will be so much simpler to handle meridian flips.
Any other suggestions?
I looked at the Orion Atlas Pro Pier extension and it seems like a painful product to use based on reviews - specially if you set up and tear down your setup every day.
I think my idea of software bracketing loses imaging time - but works without pier extensions and all the hassles that go along with it.
Don’t know where you heard that but it is not painfull at all. It attaches with three bolts and the ‘cable’ connects through it. The entire head comes off and the extension stays attached to the tripod. It is almost exactly the same as without the extension except its a little higher.
Pier extensions are almost a necessity for the Atlas.
Here is the youtube video by Dakota Starry Nights which shows how to improve the pier extension. Specially there are segments in there where the item seems to have enough mechanical slop between different parts which need to be tightened. May be the latest version of the extension does not have any of these issues.
https://www.youtube…h?v=tKnZLn-xz1k
Also, on Orion site, if you read the reviews, some people have the comment which reads something like: entire weight of the OTA and the mount rests on three screws at the top making it prone to vibrations.
I love that idea. I have the same problem and as a result can not use the meridian flip feature. Installing and removing a pier every time I set up is not something I really want do.
