I have recently been notified my the email messaging system that a target has been skipped but the message just gives RA and Dec values in decimal degrees - Could the actual target name be included as I have several events within close proximity and it takes a while to identify the problem target. The sequence seems to just mark the target as complete when it is not. Is it possible to change the tick in the target list to X if there has been a problem with a target within a sequence?
The email messaging system - told me it had skipped a target - cannot remember the exact reason (sorry) but it was cloudy so it may have been could not platesolve or centre?
Found the piece of log which shows what was happening to skip a target - it looks like it was clouds coming over. Having a bad run that night
23/01/2020 21:30:30,Error,(TSGPro2020-01-23) Error! Plate solve frame capture has timed out!
23/01/2020 21:30:31,Error,(TSGPro2020-01-23) Auto center failed! Aborting auto center (c:8)…
23/01/2020 21:30:31,Error,(TSGPro2020-01-23) Sequence recovery failed (CenteringAndGuiding)!
23/01/2020 21:30:31,Error,(TSGPro2020-01-23) Sequence recovery failed! Attempting to move to the next target…
23/01/2020 21:30:31,Status,(TSGPro2020-01-23) Sequence has started…
23/01/2020 21:30:31,Status,(TSGPro2020-01-23) Starting target “UX Dra (VSX13709)”…
23/01/2020 21:30:31,Status,(TSGPro2020-01-23) Slewing to target “UX Dra (VSX13709)”…
23/01/2020 21:30:49,Status,(TSGPro2020-01-23) SGPro is running (uncheck “Heartbeat” to supress this message)…
23/01/2020 21:31:27,Status,(TSGPro2020-01-23) Centering on target “UX Dra (VSX13709)”…
23/01/2020 21:31:49,Status,(TSGPro2020-01-23) SGPro is running (uncheck “Heartbeat” to supress this message)…
23/01/2020 21:32:49,Status,(TSGPro2020-01-23) SGPro is running (uncheck “Heartbeat” to supress this message)…
23/01/2020 21:33:49,Status,(TSGPro2020-01-23) SGPro is running (uncheck “Heartbeat” to supress this message)…
23/01/2020 21:34:49,Status,(TSGPro2020-01-23) SGPro is running (uncheck “Heartbeat” to supress this message)…
23/01/2020 21:35:48,Error,(TSGPro2020-01-23) Error! Plate solve frame capture has timed out!
23/01/2020 21:35:48,Error,(TSGPro2020-01-23) Auto center failed! Aborting auto center (c:8)…
23/01/2020 21:35:48,Error,(TSGPro2020-01-23) Failed to run auto center (or rotate), aborting sequence!
23/01/2020 21:35:49,Status,(TSGPro2020-01-23) SGPro is running (uncheck “Heartbeat” to supress this message)…
23/01/2020 21:36:49,Status,(TSGPro2020-01-23) SGPro is running (uncheck “Heartbeat” to supress this message)…
23/01/2020 21:36:50,Status,(TSGPro2020-01-23) Sequence has started…
23/01/2020 21:36:50,Status,(TSGPro2020-01-23) Starting target “U Gem (VSX14298)”…
We may consider this for future releases… For now, 3.1 is pretty much locked down (obviously truly tiny things like adding target name to a notification aside).
