Metaguide graph and connection
I was poking around with metaguide and had a question about how SGP works with it.
I notice that with PHD2 there is a docking module for it and the ability to load a profile and also a connect/disconnect button as well as a graph.
However no such thing exists for Metaguide.
Any particular reason? I think having a metaguide docking module with the same abilities or more would be nice to have.
After all, you added one for FocusLock.
2nd. I am a PHD2 “convert”. I started playing around with MetaGuide and found that for whatever reasons I seem to be able to do better with it than PHD2. That said I’m still using PHD2 because of SGP’s tighter integration like the graph, and the ability to wait for PHD to tell SGP that it is done settling (you can set up how many pixels for how long).
With MetaGuide all I can do is have SGP issue the dither then start a timer to wait for settling, then it’s going to start the next capture. I have yet to find an ideal setting for that that saves me time yet still allows for odd things to happen now and then.
Instead you end up with a wasted frame (this time) when something oddball happens.
This wasn’t so bad when I was doing LRGB but it’s extremely painful now that I’m doing 10min+ Narrowband subs.
So I would like the join in supporting the idea that MetaGuide support be brought more in-line with the others. I brought this up on MetaGuides forums and the response I got is that all the needed stuff should be in MetaGuide to support all that already.
Hope this helps
Thanks for your time and consideration.
