More Auto Focus Problerms
Hi there - I haven’t been able to get auto-focus to work consistently. For many months, it would fail, return to original position and I’d just keep going since I was always careful to get good focus with the Bahtinov mask. Still, it was annoying that it could never find focus. My rig is a Vixen 200SS (8" Newtonian), SBIG 8300ST, iOptron CEM40, and a Pegasus FocusCube. I ran through the step calculation (stepvalue@4x HFR at infocus position - stepvalue@in-focus position) x 2 divided by (9-1) Backlash compensation is admittedly a complete guess (by the way, my focus step range is something like 0-6000). When I run it, my graph sometimes looks like a perfect “V” but many times, the half-flux radius of the second point from the farthest outward point actually comes back with a larger half-flux radius than the farthest point. Not sure how that’s possible. Then the third focus point, the half flux radius will drop significantly, and so on with the resat of the expected “V” curve.
Last night, I had a good focus with the Bahtanov mask at 5104. Half flux radius was about 1.2. The auto focus routine actually worked for once and didn’t error out like it usually does, but it settled in at 5044 which actually put the scope OUT of focus.
In reviewing the log, I see a warning:
[08/23/24 21:50:16.073][WARN][Camera Thread][AF;] Warning! Auto focus validation frame Half Flux Radius (3.22) might be out of tolerance with respect to expected Half Flux Radius (0.85 or lower).
Why would it recognise that the HFR at 3.22 is HIGHER than .85 and in fact higher than my original HFR of 1.2 and then set it to 5044 at 3.22 anyway??? This happens all the time. If it isn’t this error, then many times it will keep drawing the focus tube in for countless data points until the stars are the size of grapefruits and have this “V” curve where the HFR just keeps going up, and up, and up…until it just aborts. SO we’ve been sticking solely with the Bahtinov mask and just can’t use auto-focus.
I don’t know how to provide my log as it won’t allow me to upload a log file. I think there is some way to link my account to the forum but damned if I know how. Here is a log excerpt:
[08/23/24 21:08:43.950][DEBUG][Main Thread][NONE] Could not restore switch cache for PegasusAstro PPB => Cache file not found! Cannot restore ASCOM options cache for PegasusAstro PPB, child_switches => C:\Users\Primalucelab\AppData\Local\SequenceGenerator\AscomOptionsCache\PegasusAstroPPB_child_switches.cache
[08/23/24 21:08:43.950][DEBUG][Main Thread][NONE] SwitchDeviceID: PegasusAstro PPB
SwitchDeviceName: PegasusAstro PPB
Connected: False
HasValidChildSwitchList: False
NumChildSwitches: 0
[08/23/24 21:48:23.966][INFO][Camera Thread][AF;] Performing Sequence Generator auto focus using Half Flux Radius. AFID: 1
[08/23/24 21:48:23.985][DEBUG][AfChartThread][AF;] Showing AF chart dialog…
[08/23/24 21:48:24.303][INFO][Camera Thread][AF;] Auto focus data
[08/23/24 21:48:24.303][INFO][Camera Thread][AF;] - Data Points: 9
[08/23/24 21:48:24.303][INFO][Camera Thread][AF;] - Step Size: 42
[08/23/24 21:48:24.303][INFO][Camera Thread][AF;] - Current Position: 5104
[08/23/24 21:48:24.303][INFO][Camera Thread][AF;] - Initial Move Position: 5272
[08/23/24 21:48:24.303][INFO][Camera Thread][AF;] - Panic Move Position: 5104
[08/23/24 21:48:24.317][DEBUG][Camera Thread][AF;] AbortSignal “Global Abort Signal” check; value is False
[08/23/24 21:48:24.320][INFO][Camera Thread][AF;] Moving focuser to next position (5272)…
[08/23/24 21:48:24.320][DEBUG][Camera Thread][AF;] MoveFocuserAbs: Start, move to 5272…
[08/23/24 21:48:24.321][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - start…
[08/23/24 21:48:24.321][DEBUG][Camera Thread][AF;] Focuser moving to 5272
[08/23/24 21:48:24.340][DEBUG][Camera Thread][AF;] Focuser move call complete
[08/23/24 21:48:24.340][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread is started…
[08/23/24 21:48:25.341][DEBUG][Camera Thread][AF;] AbortSignal “AutoFocusAbortSignal” check; value is False
[08/23/24 21:48:27.342][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread → movement complete
[08/23/24 21:48:27.342][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - Focuser reports it is done moving, continuing…
[08/23/24 21:48:27.342][DEBUG][Camera Thread][AF;] MoveFocuserAbs: End, move complete, at 5272…
[08/23/24 21:48:27.342][DEBUG][Camera Thread][AF;] Calculating step metric…
[08/23/24 21:48:27.343][DEBUG][Camera Thread][AF;] Taking auto focus frame(s)…
[08/23/24 21:48:27.345][DEBUG][Camera Thread][AF;] SBIG camera: Capturing auto focus frame…
[08/23/24 21:48:27.345][DEBUG][Camera Thread][AF;] SBIG AF Binning: 2x2…
[08/23/24 21:48:27.345][DEBUG][Camera Thread][AF;] SBIG AF Exposure length: 6 seconds…
[08/23/24 21:48:27.345][DEBUG][Camera Thread][AF;] SBIG: AF Exposure DL speed: NORMAL
[08/23/24 21:48:27.367][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:48:27.367][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:48:27.367][DEBUG][Camera Thread][AF;] SBIG Camera: CaptureImage…
[08/23/24 21:48:27.367][DEBUG][Camera Thread][AF;] SBIG Camera: Start exposure…
[08/23/24 21:48:27.367][DEBUG][Camera Thread][AF;] SBIG Camera: EnableRBIPreflash(False)
[08/23/24 21:48:27.367][DEBUG][Camera Thread][AF;] SBIG Camera: fetch customer options…
[08/23/24 21:48:27.367][DEBUG][Camera Thread][AF;] SBIG Camera: exposure time = 600
[08/23/24 21:48:27.367][DEBUG][Camera Thread][AF;] SBIG Camera: shutter is open…
[08/23/24 21:48:27.775][DEBUG][Camera Thread][AF;] SBIG Camera: capture command sent…
[08/23/24 21:48:33.793][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATING
[08/23/24 21:48:34.794][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATION_COMPLETE
[08/23/24 21:48:34.816][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:48:34.816][DEBUG][Camera Thread][AF;] SBIG Camera: read data…
[08/23/24 21:48:34.816][DEBUG][Camera Thread][AF;] SBIG Camera: starting readout…
[08/23/24 21:48:34.816][DEBUG][Camera Thread][AF;] SBIG Camera: reading lines…
[08/23/24 21:48:34.951][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:48:34.951][DEBUG][Camera Thread][AF;] SBIG read complete. Took 135ms…
[08/23/24 21:48:34.953][DEBUG][Camera Thread][AF;] Auto focus exposure complete, downloading…
[08/23/24 21:48:34.957][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame display AF frame preview…
[08/23/24 21:48:34.957][DEBUG][Camera Thread][AF;] Internal Interface: Set Preview…
[08/23/24 21:48:34.957][DEBUG][Camera Thread][AF;] MDI Open Image requires UI thread delegate to open image…
[08/23/24 21:48:34.957][DEBUG][Camera Thread][AF;] Delegate created, invoking…
[08/23/24 21:48:34.957][DEBUG][Camera Thread][AF;] Delegate created, invoked, blocking until render is complete…
[08/23/24 21:48:34.959][DEBUG][Main Thread][AF;] MDI Open Image: start…
[08/23/24 21:48:35.052][DEBUG][Main Thread][AF;] → Find stars with max concurrency: 2
[08/23/24 21:48:35.208][DEBUG][Camera Thread][AF;] Calling EndInvoke…
[08/23/24 21:48:35.496][DEBUG][Main Thread][AF;] Star detection using min star size of 3px…
[08/23/24 21:48:35.496][DEBUG][Main Thread][AF;] Star detection using max star size of 60px…
[08/23/24 21:48:35.511][INFO][Main Thread][AF;] Find Stars should measure eccentricity: True…
[08/23/24 21:48:35.548][DEBUG][Main Thread][AF;] Find stars took: 495 ms…
[08/23/24 21:48:35.582][DEBUG][Main Thread][AF;] Star list contains 2 stars…
[08/23/24 21:48:35.663][DEBUG][Main Thread][AF;] ImageViewer Fit to screen…
[08/23/24 21:48:35.663][DEBUG][Main Thread][AF;] FitToScreen => xRatio: 0.91; yRatio: 0.53
[08/23/24 21:48:35.663][DEBUG][Main Thread][AF;] FitToScreen => panelWidth: 1526; panelHeight: 672
[08/23/24 21:48:35.663][DEBUG][Main Thread][AF;] FitToScreen => imgWidth: 1676; imgHeight: 1266
[08/23/24 21:48:35.663][DEBUG][Main Thread][AF;] FitToScreen => Calculated Zoom => 0.531; Bounds => {X=0,Y=0,Width=890,Height=672}
[08/23/24 21:48:35.689][DEBUG][Main Thread][AF;] Display Image => Size to fit used…
[08/23/24 21:48:35.701][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame success…
[08/23/24 21:48:36.706][DEBUG][Camera Thread][AF;] Auto focus Half Flux Radius calculated at: 6.70 with 4 stars
[08/23/24 21:48:36.723][INFO][Camera Thread][AF;] Incremental Fit Result (1): quality=%; a=0; b=0; c=0;
[08/23/24 21:48:36.724][INFO][Camera Thread][AF;] Moving focuser to next position (5230)…
[08/23/24 21:48:36.724][DEBUG][Camera Thread][AF;] MoveFocuserAbs: Start, move to 5230…
[08/23/24 21:48:36.724][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - start…
[08/23/24 21:48:36.724][DEBUG][Camera Thread][AF;] Focuser moving to 5230
[08/23/24 21:48:36.748][DEBUG][Camera Thread][AF;] Focuser move call complete
[08/23/24 21:48:36.749][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread is started…
[08/23/24 21:48:37.749][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread → movement complete
[08/23/24 21:48:38.750][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - Focuser reports it is done moving, continuing…
[08/23/24 21:48:38.750][DEBUG][Camera Thread][AF;] MoveFocuserAbs: End, move complete, at 5230…
[08/23/24 21:48:38.750][DEBUG][Camera Thread][AF;] Calculating step metric…
[08/23/24 21:48:38.750][DEBUG][Camera Thread][AF;] Taking auto focus frame(s)…
[08/23/24 21:48:38.752][DEBUG][Camera Thread][AF;] SBIG camera: Capturing auto focus frame…
[08/23/24 21:48:38.752][DEBUG][Camera Thread][AF;] SBIG AF Binning: 2x2…
[08/23/24 21:48:38.752][DEBUG][Camera Thread][AF;] SBIG AF Exposure length: 6 seconds…
[08/23/24 21:48:38.752][DEBUG][Camera Thread][AF;] SBIG: AF Exposure DL speed: NORMAL
[08/23/24 21:48:38.774][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:48:38.774][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:48:38.774][DEBUG][Camera Thread][AF;] SBIG Camera: CaptureImage…
[08/23/24 21:48:38.774][DEBUG][Camera Thread][AF;] SBIG Camera: Start exposure…
[08/23/24 21:48:38.774][DEBUG][Camera Thread][AF;] SBIG Camera: EnableRBIPreflash(False)
[08/23/24 21:48:38.774][DEBUG][Camera Thread][AF;] SBIG Camera: fetch customer options…
[08/23/24 21:48:38.774][DEBUG][Camera Thread][AF;] SBIG Camera: exposure time = 600
[08/23/24 21:48:38.774][DEBUG][Camera Thread][AF;] SBIG Camera: shutter is open…
[08/23/24 21:48:39.187][DEBUG][Camera Thread][AF;] SBIG Camera: capture command sent…
[08/23/24 21:48:45.201][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATING
[08/23/24 21:48:46.201][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATION_COMPLETE
[08/23/24 21:48:46.223][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:48:46.223][DEBUG][Camera Thread][AF;] SBIG Camera: read data…
[08/23/24 21:48:46.223][DEBUG][Camera Thread][AF;] SBIG Camera: starting readout…
[08/23/24 21:48:46.223][DEBUG][Camera Thread][AF;] SBIG Camera: reading lines…
[08/23/24 21:48:46.502][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:48:46.502][DEBUG][Camera Thread][AF;] SBIG read complete. Took 279ms…
[08/23/24 21:48:46.504][DEBUG][Camera Thread][AF;] Auto focus exposure complete, downloading…
[08/23/24 21:48:46.507][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame display AF frame preview…
[08/23/24 21:48:46.507][DEBUG][Camera Thread][AF;] Internal Interface: Set Preview…
[08/23/24 21:48:46.507][DEBUG][Camera Thread][AF;] MDI Open Image requires UI thread delegate to open image…
[08/23/24 21:48:46.507][DEBUG][Camera Thread][AF;] Delegate created, invoking…
[08/23/24 21:48:46.507][DEBUG][Camera Thread][AF;] Delegate created, invoked, blocking until render is complete…
[08/23/24 21:48:46.509][DEBUG][Main Thread][AF;] MDI Open Image: start…
[08/23/24 21:48:46.593][DEBUG][Main Thread][AF;] → Find stars with max concurrency: 2
[08/23/24 21:48:46.759][DEBUG][Camera Thread][AF;] Calling EndInvoke…
[08/23/24 21:48:47.015][DEBUG][Main Thread][AF;] Star detection using min star size of 3px…
[08/23/24 21:48:47.015][DEBUG][Main Thread][AF;] Star detection using max star size of 60px…
[08/23/24 21:48:47.030][INFO][Main Thread][AF;] Find Stars should measure eccentricity: True…
[08/23/24 21:48:47.065][DEBUG][Main Thread][AF;] Find stars took: 471 ms…
[08/23/24 21:48:47.096][DEBUG][Main Thread][AF;] Star list contains 2 stars…
[08/23/24 21:48:47.170][DEBUG][Main Thread][AF;] ImageViewer Fit to screen…
[08/23/24 21:48:47.170][DEBUG][Main Thread][AF;] FitToScreen => xRatio: 0.91; yRatio: 0.53
[08/23/24 21:48:47.170][DEBUG][Main Thread][AF;] FitToScreen => panelWidth: 1526; panelHeight: 672
[08/23/24 21:48:47.170][DEBUG][Main Thread][AF;] FitToScreen => imgWidth: 1676; imgHeight: 1266
[08/23/24 21:48:47.170][DEBUG][Main Thread][AF;] FitToScreen => Calculated Zoom => 0.531; Bounds => {X=0,Y=0,Width=890,Height=672}
[08/23/24 21:48:47.195][DEBUG][Main Thread][AF;] Display Image => Size to fit used…
[08/23/24 21:48:47.208][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame success…
[08/23/24 21:48:48.215][DEBUG][Camera Thread][AF;] Auto focus Half Flux Radius calculated at: 5.93 with 4 stars
[08/23/24 21:48:48.221][INFO][Camera Thread][AF;] Incremental Fit Result (2): quality=%; a=0; b=0; c=0;
[08/23/24 21:48:48.225][INFO][Camera Thread][AF;] Moving focuser to next position (5188)…
[08/23/24 21:48:48.225][DEBUG][Camera Thread][AF;] MoveFocuserAbs: Start, move to 5188…
[08/23/24 21:48:48.225][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - start…
[08/23/24 21:48:48.225][DEBUG][Camera Thread][AF;] Focuser moving to 5188
[08/23/24 21:48:48.245][DEBUG][Camera Thread][AF;] Focuser move call complete
[08/23/24 21:48:48.246][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread is started…
[08/23/24 21:48:49.247][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - Focuser reports it is done moving, continuing…
[08/23/24 21:48:49.247][DEBUG][Camera Thread][AF;] MoveFocuserAbs: End, move complete, at 5188…
[08/23/24 21:48:49.247][DEBUG][Camera Thread][AF;] Calculating step metric…
[08/23/24 21:48:49.247][DEBUG][Camera Thread][AF;] Taking auto focus frame(s)…
[08/23/24 21:48:49.249][DEBUG][Camera Thread][AF;] SBIG camera: Capturing auto focus frame…
[08/23/24 21:48:49.249][DEBUG][Camera Thread][AF;] SBIG AF Binning: 2x2…
[08/23/24 21:48:49.249][DEBUG][Camera Thread][AF;] SBIG AF Exposure length: 6 seconds…
[08/23/24 21:48:49.249][DEBUG][Camera Thread][AF;] SBIG: AF Exposure DL speed: NORMAL
[08/23/24 21:48:49.271][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:48:49.271][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:48:49.271][DEBUG][Camera Thread][AF;] SBIG Camera: CaptureImage…
[08/23/24 21:48:49.271][DEBUG][Camera Thread][AF;] SBIG Camera: Start exposure…
[08/23/24 21:48:49.271][DEBUG][Camera Thread][AF;] SBIG Camera: EnableRBIPreflash(False)
[08/23/24 21:48:49.271][DEBUG][Camera Thread][AF;] SBIG Camera: fetch customer options…
[08/23/24 21:48:49.271][DEBUG][Camera Thread][AF;] SBIG Camera: exposure time = 600
[08/23/24 21:48:49.271][DEBUG][Camera Thread][AF;] SBIG Camera: shutter is open…
[08/23/24 21:48:49.699][DEBUG][Camera Thread][AF;] SBIG Camera: capture command sent…
[08/23/24 21:48:50.248][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread → movement complete
[08/23/24 21:48:55.712][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATING
[08/23/24 21:48:56.714][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATION_COMPLETE
[08/23/24 21:48:56.736][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:48:56.736][DEBUG][Camera Thread][AF;] SBIG Camera: read data…
[08/23/24 21:48:56.736][DEBUG][Camera Thread][AF;] SBIG Camera: starting readout…
[08/23/24 21:48:56.736][DEBUG][Camera Thread][AF;] SBIG Camera: reading lines…
[08/23/24 21:48:56.937][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:48:56.937][DEBUG][Camera Thread][AF;] SBIG read complete. Took 202ms…
[08/23/24 21:48:56.939][DEBUG][Camera Thread][AF;] Auto focus exposure complete, downloading…
[08/23/24 21:48:56.942][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame display AF frame preview…
[08/23/24 21:48:56.942][DEBUG][Camera Thread][AF;] Internal Interface: Set Preview…
[08/23/24 21:48:56.942][DEBUG][Camera Thread][AF;] MDI Open Image requires UI thread delegate to open image…
[08/23/24 21:48:56.942][DEBUG][Camera Thread][AF;] Delegate created, invoking…
[08/23/24 21:48:56.942][DEBUG][Camera Thread][AF;] Delegate created, invoked, blocking until render is complete…
[08/23/24 21:48:56.945][DEBUG][Main Thread][AF;] MDI Open Image: start…
[08/23/24 21:48:57.027][DEBUG][Main Thread][AF;] → Find stars with max concurrency: 2
[08/23/24 21:48:57.194][DEBUG][Camera Thread][AF;] Calling EndInvoke…
[08/23/24 21:48:57.462][DEBUG][Main Thread][AF;] Star detection using min star size of 3px…
[08/23/24 21:48:57.462][DEBUG][Main Thread][AF;] Star detection using max star size of 60px…
[08/23/24 21:48:57.513][INFO][Main Thread][AF;] Find Stars should measure eccentricity: True…
[08/23/24 21:48:57.560][DEBUG][Main Thread][AF;] Find stars took: 533 ms…
[08/23/24 21:48:57.594][DEBUG][Main Thread][AF;] Star list contains 2 stars…
[08/23/24 21:48:57.668][DEBUG][Main Thread][AF;] ImageViewer Fit to screen…
[08/23/24 21:48:57.669][DEBUG][Main Thread][AF;] FitToScreen => xRatio: 0.91; yRatio: 0.53
[08/23/24 21:48:57.669][DEBUG][Main Thread][AF;] FitToScreen => panelWidth: 1526; panelHeight: 672
[08/23/24 21:48:57.669][DEBUG][Main Thread][AF;] FitToScreen => imgWidth: 1676; imgHeight: 1266
[08/23/24 21:48:57.669][DEBUG][Main Thread][AF;] FitToScreen => Calculated Zoom => 0.531; Bounds => {X=0,Y=0,Width=890,Height=672}
[08/23/24 21:48:57.700][DEBUG][Main Thread][AF;] Display Image => Size to fit used…
[08/23/24 21:48:57.711][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame success…
[08/23/24 21:48:58.716][DEBUG][Camera Thread][AF;] Auto focus Half Flux Radius calculated at: 6.52 with 4 stars
[08/23/24 21:48:58.718][INFO][Camera Thread][AF;] Incremental Fit Result (3): quality=%; a=0; b=0; c=0;
[08/23/24 21:48:58.719][INFO][Camera Thread][AF;] Moving focuser to next position (5146)…
[08/23/24 21:48:58.719][DEBUG][Camera Thread][AF;] MoveFocuserAbs: Start, move to 5146…
[08/23/24 21:48:58.719][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - start…
[08/23/24 21:48:58.719][DEBUG][Camera Thread][AF;] Focuser moving to 5146
[08/23/24 21:48:58.732][DEBUG][Camera Thread][AF;] Focuser move call complete
[08/23/24 21:48:58.732][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread is started…
[08/23/24 21:48:59.734][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread → movement complete
[08/23/24 21:49:00.735][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - Focuser reports it is done moving, continuing…
[08/23/24 21:49:00.735][DEBUG][Camera Thread][AF;] MoveFocuserAbs: End, move complete, at 5146…
[08/23/24 21:49:00.735][DEBUG][Camera Thread][AF;] Calculating step metric…
[08/23/24 21:49:00.735][DEBUG][Camera Thread][AF;] Taking auto focus frame(s)…
[08/23/24 21:49:00.736][DEBUG][Camera Thread][AF;] SBIG camera: Capturing auto focus frame…
[08/23/24 21:49:00.736][DEBUG][Camera Thread][AF;] SBIG AF Binning: 2x2…
[08/23/24 21:49:00.736][DEBUG][Camera Thread][AF;] SBIG AF Exposure length: 6 seconds…
[08/23/24 21:49:00.736][DEBUG][Camera Thread][AF;] SBIG: AF Exposure DL speed: NORMAL
[08/23/24 21:49:00.758][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:49:00.758][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:49:00.758][DEBUG][Camera Thread][AF;] SBIG Camera: CaptureImage…
[08/23/24 21:49:00.758][DEBUG][Camera Thread][AF;] SBIG Camera: Start exposure…
[08/23/24 21:49:00.758][DEBUG][Camera Thread][AF;] SBIG Camera: EnableRBIPreflash(False)
[08/23/24 21:49:00.758][DEBUG][Camera Thread][AF;] SBIG Camera: fetch customer options…
[08/23/24 21:49:00.758][DEBUG][Camera Thread][AF;] SBIG Camera: exposure time = 600
[08/23/24 21:49:00.758][DEBUG][Camera Thread][AF;] SBIG Camera: shutter is open…
[08/23/24 21:49:01.160][DEBUG][Camera Thread][AF;] SBIG Camera: capture command sent…
[08/23/24 21:49:07.174][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATING
[08/23/24 21:49:08.175][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATION_COMPLETE
[08/23/24 21:49:08.196][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:49:08.196][DEBUG][Camera Thread][AF;] SBIG Camera: read data…
[08/23/24 21:49:08.196][DEBUG][Camera Thread][AF;] SBIG Camera: starting readout…
[08/23/24 21:49:08.197][DEBUG][Camera Thread][AF;] SBIG Camera: reading lines…
[08/23/24 21:49:08.330][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:49:08.330][DEBUG][Camera Thread][AF;] SBIG read complete. Took 132ms…
[08/23/24 21:49:08.331][DEBUG][Camera Thread][AF;] Auto focus exposure complete, downloading…
[08/23/24 21:49:08.334][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame display AF frame preview…
[08/23/24 21:49:08.334][DEBUG][Camera Thread][AF;] Internal Interface: Set Preview…
[08/23/24 21:49:08.334][DEBUG][Camera Thread][AF;] MDI Open Image requires UI thread delegate to open image…
[08/23/24 21:49:08.334][DEBUG][Camera Thread][AF;] Delegate created, invoking…
[08/23/24 21:49:08.334][DEBUG][Camera Thread][AF;] Delegate created, invoked, blocking until render is complete…
[08/23/24 21:49:08.342][DEBUG][Main Thread][AF;] MDI Open Image: start…
[08/23/24 21:49:08.426][DEBUG][Main Thread][AF;] → Find stars with max concurrency: 2
[08/23/24 21:49:08.586][DEBUG][Camera Thread][AF;] Calling EndInvoke…
[08/23/24 21:49:08.850][DEBUG][Main Thread][AF;] Star detection using min star size of 3px…
[08/23/24 21:49:08.850][DEBUG][Main Thread][AF;] Star detection using max star size of 60px…
[08/23/24 21:49:08.871][INFO][Main Thread][AF;] Find Stars should measure eccentricity: True…
[08/23/24 21:49:08.903][DEBUG][Main Thread][AF;] Find stars took: 476 ms…
[08/23/24 21:49:08.932][DEBUG][Main Thread][AF;] Star list contains 2 stars…
[08/23/24 21:49:09.009][DEBUG][Main Thread][AF;] ImageViewer Fit to screen…
[08/23/24 21:49:09.009][DEBUG][Main Thread][AF;] FitToScreen => xRatio: 0.91; yRatio: 0.53
[08/23/24 21:49:09.009][DEBUG][Main Thread][AF;] FitToScreen => panelWidth: 1526; panelHeight: 672
[08/23/24 21:49:09.009][DEBUG][Main Thread][AF;] FitToScreen => imgWidth: 1676; imgHeight: 1266
[08/23/24 21:49:09.009][DEBUG][Main Thread][AF;] FitToScreen => Calculated Zoom => 0.531; Bounds => {X=0,Y=0,Width=890,Height=672}
[08/23/24 21:49:09.033][DEBUG][Main Thread][AF;] Display Image => Size to fit used…
[08/23/24 21:49:09.044][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame success…
[08/23/24 21:49:10.049][DEBUG][Camera Thread][AF;] Auto focus Half Flux Radius calculated at: 4.22 with 4 stars
[08/23/24 21:49:10.053][INFO][Camera Thread][AF;] Incremental Fit Result (4): quality=76%; a=-217.821062067869; b=2285.51140309692; c=-5988.61628313854;
[08/23/24 21:49:10.054][INFO][Camera Thread][AF;] Moving focuser to next position (5104)…
[08/23/24 21:49:10.054][DEBUG][Camera Thread][AF;] MoveFocuserAbs: Start, move to 5104…
[08/23/24 21:49:10.054][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - start…
[08/23/24 21:49:10.054][DEBUG][Camera Thread][AF;] Focuser moving to 5104
[08/23/24 21:49:10.100][DEBUG][Camera Thread][AF;] Focuser move call complete
[08/23/24 21:49:10.101][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread is started…
[08/23/24 21:49:11.102][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread → movement complete
[08/23/24 21:49:11.102][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - Focuser reports it is done moving, continuing…
[08/23/24 21:49:11.102][DEBUG][Camera Thread][AF;] MoveFocuserAbs: End, move complete, at 5104…
[08/23/24 21:49:11.102][DEBUG][Camera Thread][AF;] Calculating step metric…
[08/23/24 21:49:11.102][DEBUG][Camera Thread][AF;] Taking auto focus frame(s)…
[08/23/24 21:49:11.104][DEBUG][Camera Thread][AF;] SBIG camera: Capturing auto focus frame…
[08/23/24 21:49:11.104][DEBUG][Camera Thread][AF;] SBIG AF Binning: 2x2…
[08/23/24 21:49:11.104][DEBUG][Camera Thread][AF;] SBIG AF Exposure length: 6 seconds…
[08/23/24 21:49:11.104][DEBUG][Camera Thread][AF;] SBIG: AF Exposure DL speed: NORMAL
[08/23/24 21:49:11.125][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:49:11.125][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:49:11.125][DEBUG][Camera Thread][AF;] SBIG Camera: CaptureImage…
[08/23/24 21:49:11.125][DEBUG][Camera Thread][AF;] SBIG Camera: Start exposure…
[08/23/24 21:49:11.125][DEBUG][Camera Thread][AF;] SBIG Camera: EnableRBIPreflash(False)
[08/23/24 21:49:11.125][DEBUG][Camera Thread][AF;] SBIG Camera: fetch customer options…
[08/23/24 21:49:11.125][DEBUG][Camera Thread][AF;] SBIG Camera: exposure time = 600
[08/23/24 21:49:11.125][DEBUG][Camera Thread][AF;] SBIG Camera: shutter is open…
[08/23/24 21:49:11.524][DEBUG][Camera Thread][AF;] SBIG Camera: capture command sent…
[08/23/24 21:49:17.538][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATING
[08/23/24 21:49:18.539][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATION_COMPLETE
[08/23/24 21:49:18.562][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:49:18.562][DEBUG][Camera Thread][AF;] SBIG Camera: read data…
[08/23/24 21:49:18.562][DEBUG][Camera Thread][AF;] SBIG Camera: starting readout…
[08/23/24 21:49:18.562][DEBUG][Camera Thread][AF;] SBIG Camera: reading lines…
[08/23/24 21:49:18.739][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:49:18.739][DEBUG][Camera Thread][AF;] SBIG read complete. Took 175ms…
[08/23/24 21:49:18.740][DEBUG][Camera Thread][AF;] Auto focus exposure complete, downloading…
[08/23/24 21:49:18.742][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame display AF frame preview…
[08/23/24 21:49:18.742][DEBUG][Camera Thread][AF;] Internal Interface: Set Preview…
[08/23/24 21:49:18.742][DEBUG][Camera Thread][AF;] MDI Open Image requires UI thread delegate to open image…
[08/23/24 21:49:18.743][DEBUG][Camera Thread][AF;] Delegate created, invoking…
[08/23/24 21:49:18.743][DEBUG][Camera Thread][AF;] Delegate created, invoked, blocking until render is complete…
[08/23/24 21:49:18.743][DEBUG][Main Thread][AF;] MDI Open Image: start…
[08/23/24 21:49:18.830][DEBUG][Main Thread][AF;] → Find stars with max concurrency: 2
[08/23/24 21:49:18.994][DEBUG][Camera Thread][AF;] Calling EndInvoke…
[08/23/24 21:49:19.346][DEBUG][Main Thread][AF;] Star detection using min star size of 3px…
[08/23/24 21:49:19.346][DEBUG][Main Thread][AF;] Star detection using max star size of 60px…
[08/23/24 21:49:19.361][INFO][Main Thread][AF;] Find Stars should measure eccentricity: True…
[08/23/24 21:49:19.401][DEBUG][Main Thread][AF;] Find stars took: 571 ms…
[08/23/24 21:49:19.436][DEBUG][Main Thread][AF;] Star list contains 9 stars…
[08/23/24 21:49:19.527][DEBUG][Main Thread][AF;] ImageViewer Fit to screen…
[08/23/24 21:49:19.527][DEBUG][Main Thread][AF;] FitToScreen => xRatio: 0.91; yRatio: 0.53
[08/23/24 21:49:19.527][DEBUG][Main Thread][AF;] FitToScreen => panelWidth: 1526; panelHeight: 672
[08/23/24 21:49:19.527][DEBUG][Main Thread][AF;] FitToScreen => imgWidth: 1676; imgHeight: 1266
[08/23/24 21:49:19.527][DEBUG][Main Thread][AF;] FitToScreen => Calculated Zoom => 0.531; Bounds => {X=0,Y=0,Width=890,Height=672}
[08/23/24 21:49:19.554][DEBUG][Main Thread][AF;] Display Image => Size to fit used…
[08/23/24 21:49:19.570][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame success…
[08/23/24 21:49:20.575][DEBUG][Camera Thread][AF;] Auto focus Half Flux Radius calculated at: 2.10 with 18 stars
[08/23/24 21:49:20.578][INFO][Camera Thread][AF;] Incremental Fit Result (5): quality=94%; a=-227.020369241777; b=2381.50433359521; c=-6239.01535286957;
[08/23/24 21:49:20.583][DEBUG][Camera Thread][AF;] Emit AFPack screenshot: Points: 5; Final: False
[08/23/24 21:49:20.601][INFO][Camera Thread][AF;] Detected focus is getting better…continue
[08/23/24 21:49:20.606][INFO][Camera Thread][AF;] Moving focuser to next position (5062)…
[08/23/24 21:49:20.606][DEBUG][Camera Thread][AF;] MoveFocuserAbs: Start, move to 5062…
[08/23/24 21:49:20.606][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - start…
[08/23/24 21:49:20.606][DEBUG][Camera Thread][AF;] Focuser moving to 5062
[08/23/24 21:49:20.621][DEBUG][Camera Thread][AF;] Focuser move call complete
[08/23/24 21:49:20.621][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread is started…
[08/23/24 21:49:21.622][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread → movement complete
[08/23/24 21:49:21.622][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - Focuser reports it is done moving, continuing…
[08/23/24 21:49:21.622][DEBUG][Camera Thread][AF;] MoveFocuserAbs: End, move complete, at 5062…
[08/23/24 21:49:21.622][DEBUG][Camera Thread][AF;] Calculating step metric…
[08/23/24 21:49:21.622][DEBUG][Camera Thread][AF;] Taking auto focus frame(s)…
[08/23/24 21:49:21.626][DEBUG][Camera Thread][AF;] SBIG camera: Capturing auto focus frame…
[08/23/24 21:49:21.626][DEBUG][Camera Thread][AF;] SBIG AF Binning: 2x2…
[08/23/24 21:49:21.626][DEBUG][Camera Thread][AF;] SBIG AF Exposure length: 6 seconds…
[08/23/24 21:49:21.626][DEBUG][Camera Thread][AF;] SBIG: AF Exposure DL speed: NORMAL
[08/23/24 21:49:21.648][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:49:21.649][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:49:21.649][DEBUG][Camera Thread][AF;] SBIG Camera: CaptureImage…
[08/23/24 21:49:21.649][DEBUG][Camera Thread][AF;] SBIG Camera: Start exposure…
[08/23/24 21:49:21.649][DEBUG][Camera Thread][AF;] SBIG Camera: EnableRBIPreflash(False)
[08/23/24 21:49:21.649][DEBUG][Camera Thread][AF;] SBIG Camera: fetch customer options…
[08/23/24 21:49:21.649][DEBUG][Camera Thread][AF;] SBIG Camera: exposure time = 600
[08/23/24 21:49:21.649][DEBUG][Camera Thread][AF;] SBIG Camera: shutter is open…
[08/23/24 21:49:22.064][DEBUG][Camera Thread][AF;] SBIG Camera: capture command sent…
[08/23/24 21:49:28.079][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATING
[08/23/24 21:49:29.080][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATION_COMPLETE
[08/23/24 21:49:29.101][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:49:29.101][DEBUG][Camera Thread][AF;] SBIG Camera: read data…
[08/23/24 21:49:29.101][DEBUG][Camera Thread][AF;] SBIG Camera: starting readout…
[08/23/24 21:49:29.101][DEBUG][Camera Thread][AF;] SBIG Camera: reading lines…
[08/23/24 21:49:29.297][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:49:29.297][DEBUG][Camera Thread][AF;] SBIG read complete. Took 196ms…
[08/23/24 21:49:29.298][DEBUG][Camera Thread][AF;] Auto focus exposure complete, downloading…
[08/23/24 21:49:29.301][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame display AF frame preview…
[08/23/24 21:49:29.301][DEBUG][Camera Thread][AF;] Internal Interface: Set Preview…
[08/23/24 21:49:29.301][DEBUG][Camera Thread][AF;] MDI Open Image requires UI thread delegate to open image…
[08/23/24 21:49:29.301][DEBUG][Camera Thread][AF;] Delegate created, invoking…
[08/23/24 21:49:29.301][DEBUG][Camera Thread][AF;] Delegate created, invoked, blocking until render is complete…
[08/23/24 21:49:29.301][DEBUG][Main Thread][AF;] MDI Open Image: start…
[08/23/24 21:49:29.386][DEBUG][Main Thread][AF;] → Find stars with max concurrency: 2
[08/23/24 21:49:29.553][DEBUG][Camera Thread][AF;] Calling EndInvoke…
[08/23/24 21:49:29.798][DEBUG][Main Thread][AF;] Star detection using min star size of 3px…
[08/23/24 21:49:29.798][DEBUG][Main Thread][AF;] Star detection using max star size of 60px…
[08/23/24 21:49:29.825][INFO][Main Thread][AF;] Find Stars should measure eccentricity: True…
[08/23/24 21:49:29.857][DEBUG][Main Thread][AF;] Find stars took: 470 ms…
[08/23/24 21:49:29.885][DEBUG][Main Thread][AF;] Star list contains 44 stars…
[08/23/24 21:49:29.959][DEBUG][Main Thread][AF;] ImageViewer Fit to screen…
[08/23/24 21:49:29.959][DEBUG][Main Thread][AF;] FitToScreen => xRatio: 0.91; yRatio: 0.53
[08/23/24 21:49:29.959][DEBUG][Main Thread][AF;] FitToScreen => panelWidth: 1526; panelHeight: 672
[08/23/24 21:49:29.959][DEBUG][Main Thread][AF;] FitToScreen => imgWidth: 1676; imgHeight: 1266
[08/23/24 21:49:29.959][DEBUG][Main Thread][AF;] FitToScreen => Calculated Zoom => 0.531; Bounds => {X=0,Y=0,Width=890,Height=672}
[08/23/24 21:49:29.992][DEBUG][Main Thread][AF;] Display Image => Size to fit used…
[08/23/24 21:49:30.005][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame success…
[08/23/24 21:49:31.012][DEBUG][Camera Thread][AF;] Auto focus Half Flux Radius calculated at: 1.09 with 88 stars
[08/23/24 21:49:31.015][INFO][Camera Thread][AF;] Incremental Fit Result (6): quality=94%; a=-122.250755129849; b=1291.77462329423; c=-3405.70352215673;
[08/23/24 21:49:31.015][DEBUG][Camera Thread][AF;] Emit AFPack screenshot: Points: 6; Final: False
[08/23/24 21:49:31.021][INFO][Camera Thread][AF;] Detected focus is getting better…continue
[08/23/24 21:49:31.021][INFO][Camera Thread][AF;] Moving focuser to next position (5020)…
[08/23/24 21:49:31.021][DEBUG][Camera Thread][AF;] MoveFocuserAbs: Start, move to 5020…
[08/23/24 21:49:31.021][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - start…
[08/23/24 21:49:31.021][DEBUG][Camera Thread][AF;] Focuser moving to 5020
[08/23/24 21:49:31.044][DEBUG][Camera Thread][AF;] Focuser move call complete
[08/23/24 21:49:31.044][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread is started…
[08/23/24 21:49:32.046][DEBUG][Camera Thread][AF;] ASCOM Focuser: MoveSync - Focuser reports it is done moving, continuing…
[08/23/24 21:49:32.046][DEBUG][Camera Thread][AF;] MoveFocuserAbs: End, move complete, at 5020…
[08/23/24 21:49:32.047][DEBUG][Camera Thread][AF;] Calculating step metric…
[08/23/24 21:49:32.047][DEBUG][Camera Thread][AF;] Taking auto focus frame(s)…
[08/23/24 21:49:32.049][DEBUG][Camera Thread][AF;] SBIG camera: Capturing auto focus frame…
[08/23/24 21:49:32.049][DEBUG][Camera Thread][AF;] SBIG AF Binning: 2x2…
[08/23/24 21:49:32.049][DEBUG][Camera Thread][AF;] SBIG AF Exposure length: 6 seconds…
[08/23/24 21:49:32.049][DEBUG][Camera Thread][AF;] SBIG: AF Exposure DL speed: NORMAL
[08/23/24 21:49:32.071][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:49:32.071][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:49:32.071][DEBUG][Camera Thread][AF;] SBIG Camera: CaptureImage…
[08/23/24 21:49:32.071][DEBUG][Camera Thread][AF;] SBIG Camera: Start exposure…
[08/23/24 21:49:32.071][DEBUG][Camera Thread][AF;] SBIG Camera: EnableRBIPreflash(False)
[08/23/24 21:49:32.071][DEBUG][Camera Thread][AF;] SBIG Camera: fetch customer options…
[08/23/24 21:49:32.071][DEBUG][Camera Thread][AF;] SBIG Camera: exposure time = 600
[08/23/24 21:49:32.071][DEBUG][Camera Thread][AF;] SBIG Camera: shutter is open…
[08/23/24 21:49:32.479][DEBUG][Camera Thread][AF;] SBIG Camera: capture command sent…
[08/23/24 21:49:33.046][DEBUG][Move Monitor Thread][AF;] ASCOM Focuser: Move monitor thread → movement complete
[08/23/24 21:49:38.496][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATING
[08/23/24 21:49:39.507][DEBUG][Camera Thread][AF;] SBIG Camera status check: INTEGRATION_COMPLETE
[08/23/24 21:49:39.529][DEBUG][Camera Thread][AF;] SBIG Camera: end exposure called…
[08/23/24 21:49:39.529][DEBUG][Camera Thread][AF;] SBIG Camera: read data…
[08/23/24 21:49:39.529][DEBUG][Camera Thread][AF;] SBIG Camera: starting readout…
[08/23/24 21:49:39.530][DEBUG][Camera Thread][AF;] SBIG Camera: reading lines…
[08/23/24 21:49:39.652][DEBUG][Camera Thread][AF;] SBIG Camera: end readout…
[08/23/24 21:49:39.652][DEBUG][Camera Thread][AF;] SBIG read complete. Took 122ms…
[08/23/24 21:49:39.653][DEBUG][Camera Thread][AF;] Auto focus exposure complete, downloading…
[08/23/24 21:49:39.656][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame display AF frame preview…
[08/23/24 21:49:39.656][DEBUG][Camera Thread][AF;] Internal Interface: Set Preview…
[08/23/24 21:49:39.656][DEBUG][Camera Thread][AF;] MDI Open Image requires UI thread delegate to open image…
[08/23/24 21:49:39.656][DEBUG][Camera Thread][AF;] Delegate created, invoking…
[08/23/24 21:49:39.656][DEBUG][Camera Thread][AF;] Delegate created, invoked, blocking until render is complete…
[08/23/24 21:49:39.656][DEBUG][Main Thread][AF;] MDI Open Image: start…
[08/23/24 21:49:39.745][DEBUG][Main Thread][AF;] → Find stars with max concurrency: 2
[08/23/24 21:49:39.907][DEBUG][Camera Thread][AF;] Calling EndInvoke…
[08/23/24 21:49:40.318][DEBUG][Main Thread][AF;] Star detection using min star size of 3px…
[08/23/24 21:49:40.318][DEBUG][Main Thread][AF;] Star detection using max star size of 60px…
[08/23/24 21:49:40.334][INFO][Main Thread][AF;] Find Stars should measure eccentricity: True…
[08/23/24 21:49:40.372][DEBUG][Main Thread][AF;] Find stars took: 626 ms…
[08/23/24 21:49:40.407][DEBUG][Main Thread][AF;] Star list contains 50 stars…
[08/23/24 21:49:40.490][DEBUG][Main Thread][AF;] ImageViewer Fit to screen…
[08/23/24 21:49:40.490][DEBUG][Main Thread][AF;] FitToScreen => xRatio: 0.91; yRatio: 0.53
[08/23/24 21:49:40.490][DEBUG][Main Thread][AF;] FitToScreen => panelWidth: 1526; panelHeight: 672
[08/23/24 21:49:40.490][DEBUG][Main Thread][AF;] FitToScreen => imgWidth: 1676; imgHeight: 1266
[08/23/24 21:49:40.490][DEBUG][Main Thread][AF;] FitToScreen => Calculated Zoom => 0.531; Bounds => {X=0,Y=0,Width=890,Height=672}
[08/23/24 21:49:40.534][DEBUG][Main Thread][AF;] Display Image => Size to fit used…
[08/23/24 21:49:40.548][DEBUG][Camera Thread][AF;] CaptureAutoFocusFrame success…
[08/23/24 21:49:41.552][DEBUG][Camera Thread][AF;] Auto focus Half Flux Radius calculated at: 0.85 with 100 stars
Link to Logs
Useful Info
OS:
Ver:
Hi there would you be able to submit full logs? We have tools that can analyze them.
Further guidance here:
SGPro - Help
