Mosaic sequence
Hey guys, I am going to be using a ZWO 533MC pro on my fast portable setup. The chip is rather small, so I am considering trying a 2x1 mosaic for a side by side imaging run. Since the pixel array dimension is 3008x3008, I may end up with roughly 6000x3000.
In order to do this, I would like to image a 3 to 5 images on one frame and then move to the next for another 3 to 5 images, back and forth from there on. (I would want to have an even background sky to deal with) Should I have to use different targets for each set of frames with the two coordinates or is there an easier way to get the job done?
Yes, right now, SGPro has no special logic for returning to previous targets. The easiest way to do this, is just to right click and use one of the duplicate target options.
When we start to giver scheduling a more serious look, we’ll be adding some other options for scenarios like this.
OK. Thanks for the prompt reply
