Description
Attached with DropBox are the following files
A) NGC772_CEM120…… Sequence File
B) sg_logfile_20221213182830
C) sg_logfile_20221218171126
D) sg_logfile_20221218171949
E) sg_logfile_20221218173146
Item B is a successful night of imaging NGC772 including pier flip on 12/13/22.
Item C, D and E were done on 12/18/22, are very short, and all failed to move the scope/mount.
I tried the Control panel Telescope Nudge Control in item C. The north arrow moved the scope, but the rest (S, E, W) failed to slew, and then the N would not slew. Once I Ran Sequence, all functions responded except for the mount. It would not slew to target. And an error message stated the failure to go to target.
Item D was done with the least interference from me. I either connected the camera and Ran Sequence, or just Ran Sequence. All appeared to work except for the scope slew.
Item E is much the same as items C and D. Prior to executing, I changed the old Belkin RS232 to USB adapter for a new one. The adapter has a 6’ USB2 cable from the computer and an iOptron supplied RS232 cable to the mount.
Same results as Items C and D.
I can move the mount using its “Commander” software that is actuated when SGP connects. I can also move the mount with the handset.
I believe that at the times when the automation fails to get the mount to slew, the handset also becomes “jammed up”, and clears once shut down.
I’m looking for suggestions as what further I can do with procedure, software and hardware.
Mark
12" LX200 Classic SCT OTA, 2182mm (f/7.16)
iOptron CEM120 Mount
QHY294MM mono CMOS camera, Atik EFW2 filter wheel
SX Lodestar guide camera, 1091mm (f/3.58)
Mitsuboshi OAG5
Starizona MicroTouch for FT focuser
Starizona SCT corrector
ASCOM 6.6 SP1
SGP v3.2.0.660 Automation
Lesvedome Dome Automation
Link to Logs
OS: Win 10
Ver: 3.2.0.660
