Hello, does %ct in the file name provide the temperate as set or temperature as measured on the camera. For example, you can set at -10c but in practice it is at -9.8c. If possible, could it be as temperature set or could we add a new naming for temperature set. I’m asking as pixinsight has an improved calibration tool where you can select certain key words which is useful. You could in theory use the FITS key work SET-TEMP but the tool in pixinsight doesn’t accept the “-”.
I would also like a tag to get the SET temp so I can include it in file names without sorting getting hosed up by slightly different temps being reported.
