It looks like someone requested this back in 2016, but I saw no replies to it, so forgive me but I will ask again.
Here’s what would be nice - a sequence number for each frame over the session - regardless of nights run. The sequence number would be able to be seeded by the user at the start of the session and be incremented by SGPro at the point a frame is saved. That way, there’s no way a duplicate frame name could be created. I run the same session for a target multiple nights and it would be helpful to track the total number of frames created for a target, regardless of whether I move a particular night’s frames into a separate subfolder after a night is done. I could track flats easier via a range of frame numbers as well.
I know it’s not exactly what you are after, in a sense, you can already “seed” the frame number by adjusting the number of completed frames for the event (manually)
Ken
This is great!
It will be very usefull for the use the new version of Pixinsight WBPP in order to gather dark flats, flats and lights within a same key-word and sequence number. Will it be possible to define manually this number in order to link lights from different nights to the same flats, dark flats… ?
Best regards
Olivier
