had another couple instances on 4.1.0.832 where creating a new target from frame and mosaic creates the entry in the sequencer but the I get the . . . . on the sequencer entry creating the sequence actions … where it never completes.
This requires a close of SGP and restart to get back onto the sequencer tab
this happened in earlier versions and has not been seen for a while
does not happen all the time … only twice recently using 4.1.0.832
Can you explain “target entry error”? I’m not sure what that means. Also, I’m not sure how to interpret “…”; does that mean the the “Loading, please wait” message does not go away? If so, is it the loading message over the events or the one in the Target List?
where creating a target from frame and mosaics - this loads them to the sequencer view, adds the events etc
In some cases this does not complete… its stuck at creating the events or loading it from Frame/Mosaic …
the dots are over the events and never completes - requires a restart of SGP - the target and events then appear in the sequencer view as normal for further adding of event details
