I’m new to SGP. I was trying some practice shots and I’m having a problem running a sequence. When I press run sequence, a window pops up saying no filter wheel selected. I’m using a dslr without a filter wheel. Did I set something up wrong? If so, where do I need to adjust the setting.
I’m not sure why it’s saying that if you have selected a Canon, but you should be able to just dismiss the message and continue with the sequence.
Can you post your sequence file and we can look? Likely there is some option set that requires a filter wheel. Maybe auto focus per filter or using a specific filter for plate solving.
Also… the dialog box you are seeing is usually more specific. It usually has a sentence below that warning that starts with a “-” and indicates why SGPro wants the filter wheel to be connected.
